JORGE RODRIGUEZ Sat, 08/29/2009 - 19:19
  • Green, 3000 points or more
Yes you can , if you have SSL VPN enabled on the outside interface you can use ASDM to administer the firewall from the outside, provided you allow the source host admin access... the source must have ASDM launcher client already insalled in the host PC as you will not be able to access the firewall as https://FW_outside_ip becuase of WEBVPN.
http://www.cisco.com/en/US/docs/security/asa/asa80/asdm60/ssl_vpn_deployment_guide/deploy.html#wp1215098
daniel.sandstro... Wed, 09/23/2009 - 23:56
Well.. as far as I tested it will work fine to reach the firewalls admin page going to https://outsideip/admin
This works also if WebVPN is enabled ( providing you have allowed ASDM access for the IP adress coming from outside )
