trunking: switchport nonegotiate
Answered Question
Aug 30th, 2009
I read that in order to disable sending DTP frames, we issue "switchport nonegotiate".
But, why do we need it if we already specified that the port is in access or tunk mode already? setting a port to access or trunk disables trunk negotiation, doesn't it?
Correct Answer by Peter Paluch about 7 years 5 months ago
Hi Wassim,
A port statically set to trunk mode still sends DTP packets to inform the other side to also activate the trunk mode. Only a port set to access mode does not send DTP packets.
Best regards,
Peter
Overall Rating: 5 (2 ratings)
Correct Answer
Peter Paluch Sun, 08/30/2009 - 03:01
Hi Wassim,
Best regards,
Peter
Jon Marshall Sun, 08/30/2009 - 04:00
Peter
Now you've got me confused -
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cd45326/0#selected_message
ie. my understanding is non-negotiate stops the port sending DTP frames which is what you put in your previous thread but not this one.
Please help me out :-)
Jon
Peter Paluch Sun, 08/30/2009 - 05:55
Hi Jon,
I am sorry if I confused you. Still, I am not sure in what way I have created a confusion. Can you be more specific?
Hoping to read from you soon.
Best regards,
Peter
Jon Marshall Sun, 08/30/2009 - 05:57
Peter
"Only a port set to access mode does not send DTP packets."
A port set to trunk mode ie. "switchport mode trunk" and then set to nonegotiate as well does not send DTP frames.
Jon
Peter Paluch Sun, 08/30/2009 - 06:20
Hi Jon,
Oh, yes, that is correct. I was merely replying to the original post context where Wassim asked: "setting a port to access or trunk disables trunk negotiation, doesn't it?" - and I answered only within context of this question. It is true that my answer here is not as exhaustive as my earlier post you have indicated.
Sorry once again for creating confusion, and thanks very much indeed for pointing it up!
Best regards,
Peter
