Clarification on OSPF, point-to-multipoint network type
Answered Question
Aug 30th, 2009
I just want to make sure I understand this correctly:
I know that, when configuring OSPF, if interface type is "point-to-multipoint" for example, no DR/BDR and no neighbor command is required for proper OSPF operation.
I just want to confirm that it is true even when I am configuring "point-to-multipoint" on Frame-Relay, which is NBMA?
Correct Answer by Edison Ortiz about 7 years 11 months ago
When configuration OSPF, if the OSPF Network Type (not the interface) is point-to-multipoint, you won't have DR/BDR election in the segment and no neighbor command is required.
Frame-Relay does not have a 'point-to-multipoint' interface, it has 'multipoint' or 'point-to-point'
R1(config)#int s0/0.111 ?
multipoint Treat as a multipoint link
point-to-point Treat as a point-to-point link
and enabling OSPF on a multipoint subinterface produces the same result as enable OSPF on the main interface under frame-relay, the OSPF network type will be Non-broadcast.
R1#sh run int s0/0.123
Building configuration...
Current configuration : 130 bytes
interface Serial0/0.123 multipoint
ip address 192.168.123.2 255.255.255.0
frame-relay map ip 192.168.123.3 203 broadcast
end
R1#sh ip os int
Serial0/0.123 is up, line protocol is up
Internet Address 192.168.123.2/24, Area 0
Process ID 1, Router ID 192.168.123.2, Network Type NON_BROADCAST, Cost: 64
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Sun, 08/30/2009 - 19:52
  • Hall of Fame,
    Founding Member
end
R1#sh ip os int
HTH,
__
Edison.
Peter Paluch Sun, 08/30/2009 - 20:07
  • Cisco Employee,
Agree absolutely.
Marlon, if you want to read something about the theoretical background regarding the network types, I have described them earlier in this thread:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd43a87
A lengthy reading, I admit, but it might be of interest to you.
Best regards,
Peter
