Maximum Distance for NM-4B-U
Aug 31st, 2009
I need to Integrate a paging system with VG router using ISDN BRI. the manufacture for the paging system told us to use NM-4B-U module in our cisco router and I need to know what is the maximum distance supported between the two devices.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 08/31/2009 - 02:29
  • Hall of Fame,
    Founding Member
Few miles, as it is an U interface.
Check again with the manufacturer as NM-4B-U does not supports voice and they may not know what they're talking about.
JustForVoice_2 Mon, 08/31/2009 - 14:38
Very nice.
We've already ordered the module. and we ordered two modules :)
The account manager will be very happy
About me, I evaluated you reply as extremely helpful but I did not check "Resolved my issue" because I have now new problem :)
paolo bevilacqua Mon, 08/31/2009 - 14:50
  • Hall of Fame,
    Founding Member
No worries. When buying Cisco products, always make sure a reputable professional reviews everything before, because it's complicated stuff, and it's easy to make mistakes.
paolo bevilacqua Tue, 09/01/2009 - 03:19
  • Hall of Fame,
    Founding Member
The voice modules have V in the part number, like VIC, WVIC.
