Aug 31st, 2009
Dear All,
I'm unfamiliar and newbie to the VOIP system and need to setup small system for branch office.
I've just dug out a few related post from here (thank you netpro) and would like to ask a few question.
Here's the most similar example for my case.
please see the attach for sample diagram.
How can I configure for all international outgoing and incoming call ( with/without CUCM connection somewhere) in my router ?
Is it possible to configure all the call routing inside PBX ?
Please advise me how to set up in simplest way.
Thanks in advance
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Mon, 08/31/2009 - 04:46
What is that you want to do in practice ?
If you're the endu user I recommend you locate a reputable cisco consulatant, because if you try this alone, you can semd a lot of time beforemaking it work 100% perfect.
yelynntun Mon, 08/31/2009 - 07:24
Thank you bevila,
I'm not going to do it for practise.
I'm quite familiar with IP routing and switching but not with the Voice traffic.
I need to set this up with PABX vendor and i'm afraid some sort of issue will arise.
yelynntun Mon, 08/31/2009 - 07:40
great, any kind help for the sample working configuration with international DID numbers ?
yelynntun Mon, 08/31/2009 - 07:56
let's say my telco assign 083 1234 500 to 083 1234 550 for my office.
How should I configure the dial peer for both outbound and inbound call ?
yelynntun Mon, 08/31/2009 - 08:07
i'm placing it on separate PBX.
Can it be done if the router is only connected to PBX and IP network ?
there's no direct PSTN connection to PBX nor router.
grazie paolo
Paolo Bevilacqua Mon, 08/31/2009 - 08:10
Yes, it can be done.
Again,please study a little when you have the router, what you want to do is not complicated but requires attention.
