ONS 15305 with MGX 8800
Aug 31st, 2009
I want to configure a Lab setup with Three ONS 15305 connected in SDH ring. Two MGX 8800 connected to ONS as provided in the diagram. ONS are connected via STM-1 and I want to connect the MGX with ONS via E1.
I wanted to know if this is a feasible solution.
I wanted to now the min configuration needed to have a talk between all of them. both the MGX confs and ONs confs.
viyuan700 Mon, 08/31/2009 - 05:42
  • Silver, 250 points or more
Yes the solution is feasible.
You have to create E1 crcuit in ONS from A to B.
Configure E1 card in MGX.
ONS dont have config like switch/router.
Check the link for ONS config guide
http://www.cisco.com/en/US/products/hw/optical/ps2001/products_configuration_guide_chapter09186a00808bdd85.html#wp1040823
You can check following links to see the config for MGX
http://www.cisco.com/en/US/products/hw/switches/ps1938/tsd_products_support_configure.html
Rajiv Dasmohapatra Tue, 09/01/2009 - 01:02
can i connect mgx and router / ONS and router via E1 with ATM encap.
how to go about it. an example or lik to example will be great.
viyuan700 Wed, 09/02/2009 - 10:19
SDH box (i.e E1 )is not concerned what protocol is going over it. if your both end routers have proper configs think should with ATM encap.
Rajiv Dasmohapatra Wed, 09/02/2009 - 10:38
what i meant was if some help regarding the configs for MGX / ONS could be found it would be a great help.
