yagnesh_tel Mon, 08/31/2009 - 05:12
Could you elaborate more on your requirement? In general, it is possible to rewrite source or destination of the packets using NAT.
randyclark Mon, 08/31/2009 - 06:10
The traffic is internal private addressing from one vlan to another. Basically they are wanting to route all traffic sent to a server to another server on another Vlan.
Ex.
Traffic sent to 10.1.1.2 on vlan1 needs to be redirected to 10.1.2.2 vlan2.
yagnesh_tel Mon, 08/31/2009 - 06:44
Hi Randy,
Are both vlan connected to same switch which provides inter-VLAN routing? What hardware is that?
A simple network topology will be helpful to understand your scenario better way.
randyclark Mon, 08/31/2009 - 07:03
The L3 is a 6509R that is doing the inter-VLAN routing. The servers are on different switches. One is on a 3750 the other a 2970G.
yagnesh_tel Mon, 08/31/2009 - 09:53
I have never done natting on 6500 with SVI interfaces involved. So keeping that in mind, here is what I will do on Router to change destination.
ip nat inside source static 10.1.2.2 10.1.1.2
interface
ip nat outside
interface
ip nat inside
This configuration will translates the destination of the IP packets that travel outside interface(s) to inside interface.
You need to configure 'ip nat outside' on all the interfaces from where traffic is coming into 6500 to access 10.1.1.2.
