I've put a 5520 in and utilizing on the inside/outside interfaces. With that said, I don't want to use the Management interface. Is it possible to SSH to the inside interface? Or am I going to be forced to use M0/0?
Yes you can SSH to the inside interface. Just configure as normal and use 'inside' instead of 'management'.
Hope that helps.
