Syslog issue
Answered Question
Aug 31st, 2009
I have installed a fresh copy of LMS3.0 on Solaris 10 but I don't get any syslog reports. When I go in var/log/syslog_info there are no messages in the file. Do I need to update anything else for syslog to get the messages in syslog_info?
Correct Answer by Joe Clarke about 7 years 10 months ago
Try forcing a restart of syslogd:
svcadm disable svc:/system/system-log
svcadm enable svc:/system/system-log
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 08/31/2009 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to make sure /etc/syslog.conf is properly configured so that messages from your devices are written to syslog_info. The default config line is:
local7.info /var/log/syslog_info
(Note: there are TABs NOT spaces between local7.info and /var/log/syslog_info.)
Once this file is updated, you must restart syslogd:
kill -HUP `cat /var/run/syslogd.pid`
The default assumes you are using local7 on your devices to send syslog messages. This, too, is the default for Cisco devices. If you are using a different facility, update syslog.conf accordingly.
nawas Fri, 09/04/2009 - 06:32
I checked syslog.conf file and it is configured as you have said. I only see the following logs in syslog_info but I don't see any other logs from my devices.
Sep 1 20:15:03 sip8a tsm_backup.pl[7555]: [ID 702911 local7.info] active, backing up
Sep 1 20:25:12 sip8a tsm_backup.pl[7555]: [ID 702911 local7.info] inspected=240037,backedup=723,transferred=617.42 MB,failed=0
Sep 1 20:25:12 sip8a tsm_backup.pl[7555]: [ID 702911 local7.info] backup complete RC=0
Sep 2 20:15:02 sip8a tsm_backup.pl[1225]: [ID 702911 local7.info] beginning detection of active host
Sep 2 20:15:02 sip8a tsm_backup.pl[1225]: [ID 702911 local7.info] Cannot execute /opt/scripts/ha/ha_control.pl ... Assuming no HA a
nd this host is active
Sep 2 20:15:02 sip8a tsm_backup.pl[1225]: [ID 702911 local7.info] active, backing up
Sep 2 20:24:02 sip8a tsm_backup.pl[1225]: [ID 702911 local7.info] inspected=240149,backedup=515,transferred=746.59 MB,failed=0
Sep 2 20:24:02 sip8a tsm_backup.pl[1225]: [ID 702911 local7.info] backup complete RC=0
Sep 3 20:15:03 sip8a tsm_backup.pl[29669]: [ID 702911 local7.info] beginning detection of active host
Sep 3 20:15:03 sip8a tsm_backup.pl[29669]: [ID 702911 local7.info] Cannot execute /opt/scripts/ha/ha_control.pl ... Assuming no HA
and this host is active
Sep 3 20:15:03 sip8a tsm_backup.pl[29669]: [ID 702911 local7.info] active, backing up
Sep 3 20:26:56 sip8a tsm_backup.pl[29669]: [ID 702911 local7.info] inspected=241879,backedup=10384,transferred=2.23 GB,failed=0
Sep 3 20:26:56 sip8a tsm_backup.pl[29669]: [ID 702911 local7.info] backup complete RC=0
I have attached a copy of syslog.conf
Joe Clarke Fri, 09/04/2009 - 08:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This whole syslog.conf looks wrong as spaces are used instead of tabs. Perhaps you did some kind of conversion when you posted it. If it is really using spaces, fix it so all spaces are tabs.
Other than that, make sure your devices are sending syslogs using the local7 facility. If you see another facility configured (e.g. logging facility syslog), then either fix the device, or change the facility in syslog.conf.
nawas Tue, 09/08/2009 - 10:31
file check is OK, local7 is verified,
I see the following in the syslogcollector.log
SyslogCollector - [Thread: main] INFO , 04 Sep 2009 11:08:27,613, System Initialized.
SyslogCollector - [Thread: main] WARN , 04 Sep 2009 11:08:29,726, Unable to resurrect connection to a subscriber.
SyslogCollector - [Thread: main] INFO , 04 Sep 2009 11:08:29,753, Service started...
SyslogCollector - [Thread: main] INFO , 08 Sep 2009 09:45:45,337, Logging System Initialized.
SyslogCollector - [Thread: main] INFO , 08 Sep 2009 09:45:45,339, System Initialized.
SyslogCollector - [Thread: main] WARN , 08 Sep 2009 09:45:47,372, Unable to resurrect connection to a subscriber.
SyslogCollector - [Thread: main] INFO , 08 Sep 2009 09:45:47,398, Service started...
When I try to subscribe/unsubcrible syslog server I get the following:
SyslogCollector - [Thread: Thread-12] WARN , 08 Sep 2009 12:47:57,363, Unable to add monitor for cw2klms3
Joe Clarke Tue, 09/08/2009 - 10:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Trying to subscribe to a Collector is pointless if the messages are not arriving in the syslog_info file. Is this still the case?
nawas Tue, 09/08/2009 - 11:13
Yes, no messages arriving the syslog_info.I checked syslog_info and made sure it has the one TAB and no spaces between local7.info and /var.
I have attached an original copy from the server for your review.
Joe Clarke Tue, 09/08/2009 - 11:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you're sure the devices are sending local7 messages, start a snoop on the server, then generate some messages from a test device:
snoop -o outfile -s 1518 udp port 514 and host IP
Where IP is the IP address of the device sending the messages. After you've collected enough packets, post the outfile. Of course, if no messages are captured, then this means that they are not arriving on the server, and something is blocking them in the network. Find out what is blocking udp/514, and fix it so those messages can make it to the server.
nawas Tue, 09/08/2009 - 11:31
Quick question before I do the snoop, I have three logging servers defined in my device, please see config
logging CiscoWorksServer1
logging WhatupServer
logging CiscoWorksServer2
syslog is working fine on server 1. syslog also works for what's up server but nothing works for CiscoWorksServer2
(server2 is a new install though)
1. Is there a limit that no of servers can be defined in one device?
2. Should I keep the server 2 on top and try?
When I do show log I see the following
Logging to CiscoWorksServer1, 192640 message lines logged, xml disabled,
filtering disabled
Logging to WhatupServer, 439 message lines logged, xml disabled,
filtering disabled
Logging to CiscoWorksServer2, 409 message lines logged, xml disabled,
filtering disabled
And over time number of messages logged increases for CiscoWorksServer2 which tells me that message are going somewhere in
CiscoWorksServer2 but not in the syslog_info file. Do you agree?
yjdabear Tue, 09/08/2009 - 11:41
  • Gold, 750 points or more
That's part of the problem: IOS can only log to two syslog servers.
Joe Clarke Tue, 09/08/2009 - 12:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
That's not true. You can have as many syslog servers as you want. We RECOMMEND you have no more than three.
yjdabear Wed, 09/09/2009 - 04:58
I stand corrected. I think we saw high CPU util when having 3 or more syslogging destinations.
In a similar vein, how many "snmp-server enable traps" destinations can IOS handle?
Joe Clarke Tue, 09/08/2009 - 12:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, the messages are being sent, but they're either being dropped in the network or on the server. The sniffer trace will help pinpoint which.
nawas Tue, 09/08/2009 - 13:06
Here is the snoop capture, I did the conf t and shut/no shut the interface. I generated 5 line and they show up in the capture.
Joe Clarke Tue, 09/08/2009 - 13:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try restarting syslogd on the server, and then regenerate the same messages to see if they show up in the syslog_info file:
nawas Wed, 09/09/2009 - 07:01
Restarted syslogd, regenerated the message but stil it didn't make it to syslog_info. I have attached the snoop capture.
Joe Clarke Wed, 09/09/2009 - 10:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the output of ps -efl and netstat -an.
Joe Clarke Wed, 09/09/2009 - 13:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Syslog is running, but not bound to udp/514. Post the output of:
svcprop svc:/system/system-log:default
Joe Clarke Thu, 09/10/2009 - 08:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is what I thought. Your syslog service is not configured to allow remote message reception. Run these commands as root:
svccfg -s svc:/system/system-log setprop config/log_from_remote = true
svcadm refresh svc:/system/system-log
Then you should be receiving remote messages.
Correct Answer
Joe Clarke Thu, 09/10/2009 - 10:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
nawas Thu, 09/10/2009 - 12:23
That did it. It's working now.
Thanks a lot for all your help Joe. I knew you would resolve it.
