ACE 4710 & gzip compression
Aug 31st, 2009
Hi all
I have a small problem with our 4710 (ver A3 2.2). We have enabled compression for a site, and have removed the excluded MIME types for .js and .css files from the "default-compression-exclusion-mime-type" class-map. However, all .js files are being sent uncompressed (the .css files are being compressed though).
Any ideas why this would be happening?
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 09/01/2009 - 00:51
  • Cisco Employee,
You need to specify the mime-type of the JS file.
switch/Admin(config-parammap-http)# compress ?
mimetype Configure mime-type to compress
minimum-size Configure minimum body size to compress
user-agent Configure user-agent not to compress
We only compress traffic matching the correct mimetype (default is text) and the minimum size of 512 bytes.
minimum size : 512
mimetype : [Tt][Ee][Xx][Tt]/.*
Gilles.
