Caller-ID Name not showing on Phones - CUCM 7.1.2.20000-2
Aug 31st, 2009
Hello All,
I'am having an issue where the name attached to the caller-id is not showing up on the phones. I do see the name in the ISDN q931 debug on the 2851 router. This is a PRI and I'am using H323. Any idea what I might be missing in CUCM? Thanks
Jaime Valencia Mon, 08/31/2009 - 08:53
  • Cisco Employee,
  • Hall of Fame,
    2011
If this is for incoming calls and the IE with the CNAM is not present check with your telco.
java
if this helps, please rate
steigja Mon, 08/31/2009 - 09:12
Here is what I'am seeing on the Q931 debugs
Facility i = 0x9F8B0100A11702016B020100800F4E4557204A4552534559202020202
Protocol Profile = Networking Extensions
0xA11702016B020100800F4E4557204A45525345592020202020
Component = Invoke component
Invoke Id = 107
Operation = CallingName
Name Presentation Allowed Extended
Name = NEW JERSEY
So it looks like telco is passing us the CNAM
fabien.damien Wed, 09/09/2009 - 23:32
ask your telco if it supports display IE,
from the debug it looks like they support facility IE,
if it's the case,(display IE)I used the following commands under the serial interface and it works fine:
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 12000
isdn incoming-voice voice
isdn supp-service name calling profile Network-Extension operation-value-tag local
isdn send-alerting
isdn negotiate-bchan
isdn bchan-number-order ascending
isdn sending-complete
isdn outgoing ie facility
isdn outgoing display-ie
isdn outgoing ie caller-number
isdn outgoing ie called-subaddr
no cdp enable
steigja Mon, 08/31/2009 - 09:13
Invoke Id = 107
Name = NEW JERSEY
Invoke Id = 107
Name = NEW JERSEY
