License differences?
John Blakley
All,
We're configuring new routers and noticed that the IPBase version that we're running doesn't support NTP. We need the K9 version of IPBase. Can we "legally" download it since it's in the same family?
John
HTH, John *** Please rate all useful posts ***
3 Accepted Solutions
Edison Ortiz
On routers, k9 is an updated image - more $$. On switches, the migration is free.
Don't shoot the messenger :)
__
Edison.
You might try sntp instead:
sntp server HOST
SNTP should be supported in this image.
I read the internal bug enclosure and the problem is with the online help but the command will take if entered without the help.
R1(config)#ntp server ?
vrf VPN Routing/Forwarding Information
R1(config)#ntp server 1.1.1.1
R1(config)#end
R1#sh run | i
*Aug 31 21:33:31.367: %SYS-5-CONFIG_I: Configured from console by console ntp
ntp server 1.1.1.1
R1#
R1#sh ver | i IOS
Cisco IOS Software, 7200 Software (C7200-IPBASE-M), Version 12.4(15)T9
Thanks for highlighting the bug.
16 Replies 16
Edison Ortiz
__
Edison.
Edison,
Thanks! I guess we're limited to local clock on these. :)
John
Can you expand on the feature you are after?
You can't sync to external sources without a k9 feature set?
That was it. I need to be able to sync this router to my main router that's syncing from an external time source. I don't have the option to set a server, only vrf.
John
Can you provide the show version of that router along with the output from typing ntp ? in the config mode?
Edison,
The version is:
12.4(15)T9 (c2800nm-ipbase-mz.124-15.T9.bin)
The options that I have are:
access-group
authenticate
authentication-key
broadcastdelay
clock-period
logging
master
max-associations
peer
server
source
trusted-key
update-calendar
Under ntp server ?:
vrf
And looking at the Feature navigator, it shows k9 after all of the images in order to support ntp.
John
sntp server HOST
Joe,
That looks like that might work. I'll put it in place when the branch receives it, and we'll see if it syncs.
Thanks!!
John
John,
Hostname or A.B.C.D IP address of peer
sh ver | i flash:
System image file is "flash:c2800nm-ipbase-mz.124-15.T4.bin"
I don't have T9 anywhere at the moment but I'm sure this behavior has not changed from T4 to T9 :)
Actually, it has. This is broken according to CSCsz46378. It is working in earlier releases, and in 12.4(20)T (ipbase). It is not clear if this bug will be fixed in 12.4(15)T.
I should also point out, that the problem is only with the help. You could easily just do:
ntp server 10.1.1.1
And the parser should take it. The '?' will not work, though.
R1(config)#end
R1#sh run | i
ntp server 1.1.1.1
R1#
R1#sh ver | i IOS
Edison,
Thanks for this. I did do this, and it shows the ntp config in the running configuration. When we put these routers in production, it will be interesting seeing if it really works.
Thanks!!
John
John,
It will work. I tested last night. Don't be afraid of the missing option from the online help.
It will be interesting to see what routers these are. I do remember (from a while back) that some low end routers (and low end feature sets) did not include support for NTP (trying to minimize the memory requirement).
I tried to use the Feature Navigator to check on this. But the only thing that Feature Navigator seems to show is whether there is support for NTPv4 but nothing to show whether basic NTP is supported or not.
I agree with the question that Edison asked about why John thinks that he needs the K9. If IP Base does not have NTP support then I wonder if just adding K9 will also get NTP. I wonder if it will be necessary to go up a feature set, to something like Advanced Security or Enterprise Services to get support for NTP.
Rick
Rick
