Bypassing specific traffic on Guest SSID
Aug 31st, 2009
Hey guys,
I have a guest access setup with WISM and Anchor controllers in DMZ for internet access. L2 security policy is based on WAP2+PSK awith Layer3 on web authentication. Would it be possible to let un-authenticated users to connect to some web sites say (That is without being authenticated by WLC).
Thanks in advance,
dancampb Tue, 09/01/2009 - 05:02
Sure, that is what the preauthentication ACL is for. Just create an ACL on the WLC and under the WLAN select that ACL for the preauth ACL on the layer-3 security tab. Anything that is permitted by the ACL will be allowed to pass through the controller regardless if the client has authenticated yet or not.
jaydhindsa Tue, 09/01/2009 - 07:13
Thx, I will try that. will let you know if face some problems.
Trending Topics - Security & Network
