Qos Voice/Citrix
Aug 31st, 2009
I am trying to configure Qos on our MPLS for citrix. We already have qos running for Voice and it seems to work well. No voice issues reported. Each branch has a full T1 out to the cloud. The vendor Verizon has a GOLD CAR of 512k setup for Voice which we route our Voice traffic over. I would like to tag my citrix traffic as COS=3 mission critical. I have attached out current QOS configuration. Is this ok to do the tagging this way is there a better? Also I have started to add the Citrix tag in there. any help on completing would be greatly appreciated.
Joseph W. Doherty Mon, 08/31/2009 - 16:03
You might want to double check exactly what you are getting from Verizon. My experience with their MPLS service, you need to buy real-time bandwidth separately, and other traffic falls into a 5 class model which allocates fixed bandwidth reservations, two drop points on some classes, and uses DSCP markings, not CoS markings.
Also, on non-real-time classes, exceeding the purchased CAR often isn't an issue.
PS:
BTW, your limiting your overall data rate to 512 Kbps.
wbarren Mon, 08/31/2009 - 17:53
We have already bought the real-time bandwidth from Verizon that is the 512k gold car. Thanks for pointing out the 512k restriction I was putting on the data. I have made some changes which appear to correct that.
Joseph W. Doherty Tue, 09/01/2009 - 03:37
Not really what you want, I think.
Perhaps something similar to:
(NB: syntax might be incorrect or not supported on your IOS version. You also need to check markings supported by MPLS provider.)
class-map match-any VoIP-Cntrl
match ip dscp af31
match ip dscp cs3
class-map match-all VoIP-RTP
match ip dscp ef
class-map match-all Citrix
!NB: you might want to subclassify Citrix to avoid giving preference to disk-to-disk or printing traffic
match protocol citrix
policy-map sub_int
class VoIP-Cntrl
priority percent 33
!NB: reason for policer, LLQ policer doesn't engage unless there's interface congestion provider, though, likely polices rate
police percent 33
set ip dscp EF
class VoIP-RTP
bandwidth percent 5
set ip dscp cs2
class-map Citrix
bandwidth percent 10
set ip dscp cs3
class class-default
!NB: deactivate FQ to maintain explict other class's bandwidth regardless of number of class-default flows
set ip dscp BE
interface Serial#/#/# point-to-point
description MPLS Circuit
service-policy output sub_int
