Cisco switches with Avaya IP phones
Answered Question
Aug 31st, 2009
Dear All,
We plan to implement Avaya IP phone in our network.right now we have all cisco c2950 switches for user connection. shortly we plan to have cisco POE switches for accomdating Avaya Ip phones.
Does cisco POE switches support Avaya Ip phones?we will be having both Data and Voice vlan configuration in switch port.
If its support can we configure better QOS for Voice traffic?
Correct Answer by linuxnt43 about 7 years 8 months ago
I work for a company that did this 2 years ago. It works very well now but we had some "burn in" work together with our datacom provider, to ensure that QoS really worked all the way from remote site to central office where the Avaya-ACD (PBX) resides.
We have 3560's to connect the workplace and we connect PC to the Avaya phone (Daisy chain). Works nicely all the way from remote sites some 500 km away.
We also b.t.w have home workers over Inet & VPN, these can't have QoS but it works mostly anyway. We even experiment'd with a small site over VPN. That also worked well (We DO have exellent quality Internet though) ...
So yes, Avaya equippment and Cisco stuff play along and QoS is needed when bandwith hits the roof. QoS is tricky though even for specialists - Its easy to limit by mistake (we did :o) ...
Hope this helps!
\\S.
Overall Rating: 5 (1 ratings)
Correct Answer
linuxnt43 Mon, 08/31/2009 - 22:08
Hope this helps!
\\S.
linuxnt43 Mon, 08/31/2009 - 23:00
Happy to help, because I have got so much help from the Intenet community over the years!
\\S.
Shibu1978 Wed, 09/09/2009 - 05:44
Can i have some links ,docs regarding this.
Thanks for your action.
linuxnt43 Thu, 09/10/2009 - 00:02
Well, I don't have that much in printing ... What would be interesting?
I'll give it a try:
Typical port config for PC+Phone:
interface FastEthernet0/17
switchport access vlan 10
switchport mode access
switchport voice vlan 110
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust dscp
no snmp trap link-status
auto qos voip trust
spanning-tree portfast
Though it works well -I'm not able to actually "defend" the choosen numbers for shape and share. I know we had problems a while ago, because we had values that unintentionally gave us a roof of 10 Mb on a trunk of 100Mb because we reused params from a 1 Gb trunk! This wasn't easy to remedy - so be mindful!
I sometimes suspect the use of both share and shape is somewhat fishy - but again - it works :o)
3560 general QoS ?
Again - I can't really say why, but heres the config:
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
A lot here is default from what I remeber, but may help to compare with if you get in trouble
Anything else? - I'll try to gather it for you!
Shibu1978 Wed, 09/09/2009 - 22:49
Dear,
Could you please send me some working configuration Cisco switches with Avaya IP phone
Thanks in advance
