802.1x and List of Methods
Aug 31st, 2009
Hello, I am Patricio. I have a couples of questions about 802.1x and its configurations on the c3560. 1.- If 801.1x only works with Radious, it makes sense to define a list of methods different from the default? And, How I can to associate a list of methods, different than the default, to the interfaces? Thank in advance.
Giuseppe Larosa Tue, 09/01/2009 - 09:08
Hello Patricio,
according to configuration guide the list of methods needs to use the default name:
aaa authentication dot1x {default} method1
because default is in curls and because group radious is the only supported method.
Though other keywords are visible in the command-line help string, only the group radius keywords are supported.
the result of this is that you cannot configure two different methods lists for 802.1X authentication.
Hope to help
