Cisco CallConnector 1.5.0.23
Aug 31st, 2009
On the CallConnector client contact list (IE or Outlook), any DN in the voice hunt-group parallel will give inaccurate status. It normally stuck and continuously display DN as "Ringing" status even though the phone is on idle or any other status.
All other single DN status shows correctly except DN in voice hunt-group parallel.
Attached screenshot of the DN stuck at "Ringing" state.
Have anyone come across this ?
Nicholas Matthews Mon, 08/31/2009 - 14:34
  • Red, 2250 points or more
Hi Gerald,
I filed a bug on this recently: CSCta04268
I would check the next release. If it's urgent, you can open a TAC case.
hth,
nick
Gerald Chong Mon, 08/31/2009 - 16:08
Thanks. That explain exactly my issue here.
Unfortunately the work around will not work over here since we need an accurate CDR for reporting purposes.
I will open a TAC case on this.
Thank you.
Nicholas Matthews Tue, 09/01/2009 - 04:26
You're welcome. Glad I could help.
Options are fairly limited. TAC may be able to get you a test fix temporarily, but the software isn't released yet.
-nick
