DBWalker 4.0 Build 57 Run-time Error
Answered Question
Aug 31st, 2009
I'm running the latest version of DBWalker at this time, i.e. 4.0 Build 57, and I'm getting this error message if I click on the "Walk Database" button:
Run-time error '-2147023394 (800805de)': Error reporting event - The even log file is full.
So my simple question is, how do I fix this error message so that I can use this tool again?
Kevin
Correct Answer by lindborg about 7 years 5 months ago
dbWalker writes information to the event log on start/stop (normally for scheduled runs) - sounds like your application event log is full (HD out of space?) - I'd check the event log settings and clear the logs out and try it again.
Overall Rating: 5 (1 ratings)
Correct Answer
lindborg Mon, 08/31/2009 - 17:44
