3560V2 Default Username and Password
Aug 31st, 2009
Wondering if anyone can help, I have run into a problem deploying some of the new 3560V2 Switches.
Under normal circumstances we send unconfigured switches to site, have a tech plug them into the network, allow it to DHCP up an IP address and then configure the switch using express setup through the web front end.
Basically the same procedure as is supplied in the "Catalyst 3560 Switch Getting Started Guide.pdf" Problem is we have just found with the 3650V2's there appears to be an undocumented username and password enabled on the web front end.
We have tried all the well known ones, and had no luck, our integrator hasn't been much help either.
Does anyone know what the username and password for this "Undocumented feature" is?
Code version below.
Switch#sho ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(50)SE1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 06-Apr-09 02:25 by amvarma
Image text-base: 0x00003000, data-base: 0x01700000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(50r)SE, RELEASE SOFTWARE (fc1)
Switch uptime is 8 minutes
System image file is "flash:/c3560-ipbase-mz.122-50.SE1/c3560-ipbase-mz.122-50.SE1.bin"
cisco WS-C3560V2-24PS (PowerPC405) processor (revision C0) with 122880K/8184K bytes of memory.
Processor board ID FDO1326Z0WN
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:26:0B:2F:D0:00
Motherboard assembly number : 73-11706-10
Power supply part number : 341-0266-02
Motherboard serial number : FDO13260VCZ
Power supply serial number : DCA1321H3L5
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3560V2-24PS-S
System serial number : FDO1326Z0WN
Top Assembly Part Number : 800-31038-01
Top Assembly Revision Number : B0
Version ID : V01
CLEI Code Number : COME600ARA
Hardware Board Revision Number : 0x03
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560V2-24PS 12.2(50)SE1 C3560-IPBASE-M
Configuration register is 0xF
Brendon.Ott Mon, 08/31/2009 - 18:36
Ta, but that is one of the usual candidates we have already tried and didnt work, We also tried
User: cisco
Pass: cisco
Pass: cisco
User: cisco
User: Cisco
Pass: Cisco
Not to mention various combinations of Admin and password as well.
