EIGRP on ASA
Aug 31st, 2009
I have an ASA 5520 on which I've enabled EIGRP. There are two routers to which it is a neighbor and these have equal cost distance to a network across the network. The network will automatically load-balance but the default is on a per destination basis. I would like to have it load balance on a per packet basis as we have one large load to the same destination. On the router IOS v12.4 there is a way to change this on a per interface basis (ip load-balance per-packet) but I haven't found the equivalent command in the ASA sw v 8.0(3). Does anyone know if there is such a command or another way to achieve this? Thanks.
jeffland_98 Fri, 09/04/2009 - 18:59
Yes, and it works great on a cisco router running v12. I'm trying to find the same command (or equivalent) on an ASA appliance running 8.0(3).
