LMS 3.2 - RME configuration archive
Answered Question
Aug 31st, 2009
we have created a lmsadmin username in the ACS with privige access (authorization configuration) only. This username is used to take config archives from all the network devices.
But archive is getting failed in our firewall. When we give full access in ACS for lmsadmin (conf terminal access), it works for firewall.
As per our policy, we are not supposed to provide conf access to this user name.
Please suggest.
Guru
Correct Answer by Joe Clarke about 7 years 8 months ago
In order for RME to archive the config from FWSM devices, it must be able to run the following commands:
show running
show config
show curpriv
conf t
terminal width 0 (within config mode)
terminal no monitor
Therefore, you will need to grant the RME user access to enter config mode.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 08/31/2009 - 21:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
show running
show config
show curpriv
conf t
terminal no monitor
gururajan Mon, 08/31/2009 - 21:55
Thanks for your response.
So this is applicable for any firewall device (PIX and ASA)?
Guru
Joe Clarke Mon, 08/31/2009 - 22:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes.
