Dot1x Issue
Aug 31st, 2009
Hi all, I am testing dot1x function, I am using ACS for the radius authentication.
I think the dot1x work properly in window XP SP 2 version but fail in window XP SP3 that is
When I using Window XP SP2 PC to login with correct username "abc" but invaid password, the PC will prompt me to input
second time, after second try also input invaid password, the PC will prompt me to input third time. After third try also
input invaid password, the PC will be assigned to Authen Fail vlan "999"
However, if I using window XP SP3 PC to login with correct username "abc" but invaid password, the PC will "NOT" prompt me to input second time
Auy expext can help me to fix the problem?
interface FastEthernet0/24
switchport mode access
load-interval 30
dot1x pae authenticator
dot1x port-control auto
dot1x violation-mode protect
dot1x timeout tx-period 10
dot1x max-reauth-req 5
dot1x guest-vlan 99
dot1x auth-fail vlan 999
spanning-tree portfast
