Aug 31st, 2009
Hi all, I have configured my Cisco 877 as a SSL VPN Gateway. I can connect to it when I have set the login method as local, however, when I change it to RADIUS I am no longer able to connect.
I have also enabled RADIUS for Telnet and SSH and it does work there, so it would appear that the issue lies with the SSL VPN allowing/using RADIUS as an authentication method.
To enable the RADIUS authentication, I changed the "aaa authentication list" command in the policy group to point to the RADIUS server group.
Does anyone have any ideas as to what could be causing this issue?
Thank you.
slmansfield Fri, 09/04/2009 - 09:02
The RADIUS request from your VPN client could be timing out. You could try increasing the timeout parameter.
slmansfield Sat, 09/05/2009 - 11:21
You might also check your authentication server to see if it received the authentication request and how it responded.
