Redundant call managers
Aug 31st, 2009
Hi Teeam
My cisco guys left me with 2 call manger version 6.1.2 , primary and secondary, how can i check that they done the job properly and both the CM are raided , so if one fails the other one will kick in ? how can check the settings first to see if they are raided properly without doing the obvious i.e switch one off and leaving the other one off etc ?
please advise thank you
Dennis Mink Tue, 09/01/2009 - 05:10
when you log onto your CUCM, and go to CUCM reporting, there is and option CUCM server details, this contains the information about the RAID set up per server , per default there are 2 HDD in 1+0 configuration.
aktarmumin Wed, 09/02/2009 - 00:17
thank you for this ..i went to reporting > unified CM cluster overview>but could not see anything about the raid set up server default as per your instructions ..i have attached an overview of the report generated. please advise if there anything abnormal in my set up re cluster of my CM.before i do a test by shutting down one of the CM's.
my gut feeling is that thee guys have not clustered the CMs at all or not properly.
thank you for your help.
Jaime Valencia Tue, 09/01/2009 - 05:59
Check the CUCM group, if you don't want to shut down the server to test, configure ACLs to block communication to primary server
java
if this helps, please rate
