TCL Command "leg senddigit"
Sep 1st, 2009
Do the called party hear a DTMF tone, when we use "leg senddigit leg_outgoing" command at TCL Script application?
I have tried it out, unfortunately the called party did not hear any DTMF tone? Did the Router require special files to play the DTMF tone?
paolo bevilacqua Tue, 09/01/2009 - 03:10
  • Hall of Fame,
    Founding Member
Are you using this on a pots or voip call leg ?
wahyukurnia Tue, 09/01/2009 - 07:02
I am using the script tcl on voip call leg and the final destination is on pots call leg. The calling party is from IP Phone of CME or CM.
I will use this script for sending digit DTMF after got second tone from VOIP Service Provider.
Is it possible using "leg senddigit" for voip call leg?
paolo bevilacqua Tue, 09/01/2009 - 07:29
  • Hall of Fame,
    Founding Member
According to the documentation, it is not possible. You can try playing a file with the digit recordered.
wahyukurnia Tue, 09/01/2009 - 07:38
I have tried it out using prerecorded dtmf as *.au that stored at flash. This tone generated by http://www.dialabc.com/sound/generate/. Unfortunately VOIP Srv Provider could not recognize the digit. Do you have recommendation tool that produce standard DTMF tone?
