Fax to E-mail cut off half way
Sep 1st, 2009
Im using Cisco 1751-V as voice gateway
and I configured the onramp fax-to email
When I receive from sender that using ATA-186, I only can receive half page then cut off.
But when I receive fax from other people, its working well.. can receive the whole page.
And when the sender (with ATA) sending fax to my Fax machine, its working well. I can receive the whole page on my fax machine.
Is there any additional configuration to the Voice Gateway to receive fax from ATA Sender ?
Rgrds,
David
Below is my conf
fax interface-type fax-mail
mta send server 10.10.10.1 port 25
mta send subject Fax server received a new fax from
mta send with-subject $s$
mta send postmaster fax@domain.com
mta send mail-from hostname domain.com
mta send mail-from username fax
application
service onramp flash:app_faxmail_onramp.2.0.1.3.tcl
voice-port 1/0
cptone SG
timeouts interdigit 3
connection plar 67288888
music-threshold -70
bearer-cap Speech
caller-id enable
dial-peer voice 660 mmoip
description Fax to Email
service fax_on_vfc_onramp_app out-bound
destination-pattern 67288888
information-type fax
session target mailto:faxsingapore@domain.com
dial-peer voice 661 pots
service onramp
incoming called-number 67288888
direct-inward-dial
port 1/0
paolo bevilacqua Tue, 09/01/2009 - 03:23
  • Hall of Fame,
    Founding Member
which exact IOS are you using ?
Nicholas Matthews Tue, 09/01/2009 - 04:20
  • Red, 2250 points or more
Try adding:
voice service voip
modem passthrough nse code g711u
-nick
