Cisco View 2811
Sep 1st, 2009
Dear All,
I have updated Cisco view package as below from Cisco website,
below is my IOS Version, but i could not get the Cisco View of this device,
what could be the problem
Number of Packages Selected for Install : 1
For Product(s) : CiscoView
Install Invoked by user : admin
The Package(s) Selected for Install :
NGMARShare
Successfully installed packages (2):
NGMARShare(1.4) ,Rtr2800(8.0)
Installation Completed for : CiscoView
Cisco IOS Software
, 2800 Software (C2800NM-ADVSECURITYK9-M),
Version 12.4(10c)
Joe Clarke Tue, 09/01/2009 - 07:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the list of contents under NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs and NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw.
Joe Clarke Fri, 09/04/2009 - 08:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Shutdown Daemon Manager, then copy all of the .zip files from NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw to NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs. then restart Daemon Manager, and you should be able to view the 2800.
networking11 Fri, 09/04/2009 - 09:10
Dear Clarke,
following error is displayed after doing that copying
Message
Cannot find applicable device package for DEVICE.
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the parent device to manage the component.
Joe Clarke Fri, 09/04/2009 - 09:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Make sure the casusers group has full control over all of the .zip files in both directories.
networking11 Mon, 09/07/2009 - 03:24
Dear Clarke,
if u dont mind how can we conclude the above one
Joe Clarke Mon, 09/07/2009 - 05:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
As I said previously, make sure the casusers group has full control over all .zip files in both directories. Post the output of:
cacls *.zip
From both directories.
