Warning message
Cisco 3750 QOS/COS traffic
Sep 1st, 2009
I currenlty have a Cisco 3750 in my datacentre which has a trunk port to a provider allowing certain VLAN's over (This is my A end) the B end's are encapsualated onto Cisco 2800's (this is a hub and Spoke setup). Now I have multiple VLAN's on my 3750 at Layer 3 for each VLAN that comes over the trunk as I run a dynamic routing protocol with the B end sites. What I have been asked to do is mark certain traffic on the B end and the A end. I can do this easily on the B end but I am unsure how it will work on the A end ( I need to mark VOIP and Cirtix). Can it be done with this setup on the 3750 with this setup?
Any questions or thoughts please let me know.
Cheers
Steven
ralphcarter Tue, 09/01/2009 - 10:13
I don't believe you can mark traffic on the outbound on a 3750 switch.
You can trust the trunk interface on the 3750 inbound from the provider so that the switch accepts these dscp/cos markings.
Then perform whatever policy on the inbound from the trunk.
Then on your inbound SVI's on the 3750, you can mark the traffic using access-list.
Example:
access-list 110 permit udp any any range 16384 32767
class-map VOIP
match access-group 110
policy-map APPS
class VOIP
set dscp ef
int vlan 100
service-policy input APPS
