How do I configure port bandwidth limitation on Cisco 2950 24 port?
Sep 1st, 2009
I would like to limit the user bandwidth once it enter the switch. For exmaple, limit the bandwidth to 512Kbit/s.Shld I use port-limit or policy-map? My software version is 12.1(22)EA13.Thanks for helping out!
yagnesh_tel Tue, 09/01/2009 - 04:24
  • Silver, 250 points or more
As your code supports both, you can use either 'port based traffic control-Storm Control' or you can police rate using QoS.
If your purpose is just limited to restrict bandwidth then first option is much easier to configure on per interface basis whereas by using second method you can mark violating traffic. This can be helpful if you want end to end QoS.
Refer this if you need configuration help:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swtrafc.html#wp1063295
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swqos.html#wp1045516
sam-lee Tue, 09/01/2009 - 18:40
Hi, it seems like my switch can input the policy-map command.
