SRST configuration
Sep 1st, 2009
I have configured SRST on 1861 router according to this guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srs_wlan.html#wp1351962
Is there any additional configuration I need to perform? The things is that SRST doesnt not work in case of WAN failure. I can see no debug messages, nothing at all
Dennis Mink Tue, 09/01/2009 - 05:06
what exactly does not work?
when you break your link to CUCM (i.e) your WAN link, do your phones register on the SRST router at all (show ephones/show dialpeer).
also have you set an SRST reference point in CUCM and do your phones point to it? (see your cucm settings in the phone menu)
fgasimzade Tue, 09/01/2009 - 22:49
Phones do not register on SRST. I have configured SRST reference point. My phone points to CUCM in the settings menu.
Ip addresses in CUCM SRST reference and call-manager-fallback on router are the same. What can be possible issues?
fgasimzade Tue, 09/01/2009 - 23:00
Issue is solved. I reloaded my SRST router and everything works fine now. Thank you!
