Question about voice-port and translation-profile configured on it. ISDNPRI
Sep 1st, 2009
I have voice gateways that works like MGCP.
I also configured them for SRST and voice-ports configured with voice tranlation profiles that will work as H323 gatway in fallback mode.
Sometimes configuration of translation-profiles disappear from voice-port.
the problem is that when I have secondary problem with voice gateway (translation-profiles were been disappeared from voice-port.) and I hadn't configured translation-profiles, voice gateway will not be work.
So the problem is that I should control all voice-ports in all gateways to have command translation-profile.
How I can automate this, i think,issue?
Thank you
Jaime Valencia Tue, 09/01/2009 - 06:13
  • Cisco Employee,
  • Hall of Fame,
    2011
You probably have this commands:
ccm-manager config server x.x.x.x
ccm-manager config
remove them
java
if this helps, please rate
