Could somebody recommend me IOS for IPIPGW?
Answered Question
Sep 1st, 2009
My Cisco Product manager said that for IPIPGW function I should use IOS:
S382IVS-12423 Cisco 3825 INT VOICE/VIDEO, IPIP GW, TDMIP GW
It costs 5000 GPL USD.And is too much for my budget.
Could somebody provide me cheaper price and kind of IOS for IPIPGW Gateway?
Thank you!
Correct Answer by Stoyan Stoitsev about 7 years 7 months ago
Here is the CUBE ordering guide:
http://cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/order_guide_c07_462222.html
There two licensing schemes.
1. "Pay-as-You-Grow"
- available in any IOS that has voice in it
- need to order the license for the number of simultaneous calls to support - 4, 25 and 100
GPLs:
FL-CUBE-4 - $600
FL-CUBE-25 - $2950
FL-CUBE-100 - $9950
2. Flat
- You must buy a special INT VOICE/VIDEO, IPIP GW, TDMIP GW image. There are different flavours of that image that add security and Lawful intercept features.
- You must buy FL-INTVVSRV-XXXX license which is platform dependent and has no limit to the concurrent calls.
CUBE licensing is not enforced so you can try and test it without ordering a license, though you won't be able to get support for that functionality. Experience shows that you will need support ;)
BR,
Stoyan
Overall Rating: 5 (1 ratings)
Correct Answer
Stoyan Stoitsev Tue, 09/01/2009 - 06:07
  • Bronze, 100 points or more
GPLs:
FL-CUBE-4 - $600
FL-CUBE-25 - $2950
FL-CUBE-100 - $9950
2. Flat
BR,
Stoyan
webstd.design Tue, 09/01/2009 - 06:47
This the best answer for all my questions that I posted at NetPro!
Thank you a lot! )
