Warning message
CME with ITSP that wont use digest authentication
Sep 1st, 2009
I am having issues registering a CME (2811 with 12.4.24.T) with an ITSP. When I use the configuration below, I see CME send a Register request to them but they then send back a "404 not found".
When I asked the ITSP why they are not sending back a 401 authentication challenge in response to my register request they said that they do not want me to register with them but instead send them an "authenticated call" with the ITSP provided username and password. I have no idea what that means.
Can CME send authentication on a call-by-call bases or an "authenticated call"? What would that configuration look like?
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
sip
header-passing
registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
call start slow
no call preserve
dial-peer voice 200 voip
description Inbound / Outbound to ITSP
redirect ip2ip
voice-class h323 1
voice-class sip early-offer forced
session protocol sipv2
session target ipv4:<IP address>
session transport udp
incoming called-number .
dtmf-relay rtp-nte
sip-ua
credentials username <username> password <password> realm <realm>
authentication username <username> password <password>
registrar ipv4:<IP> expires 3600
sip-server ipv4:<IP>
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Tue, 09/01/2009 - 08:36
  • Hall of Fame,
    Founding Member
What they mean, is that after you make a call, they will then sending calls for your number to the IP where the call has originated.
So, you don't need registrar config, just credentials.
You also don't need the "allow" commands and some more neither.
robert-knapp Tue, 09/01/2009 - 09:00
Just to clearify, incoming from them is working fine. With my current configuration, when I send a call to them I get a "407 proxy authentication required" message. They are expecting me to somehow send the username and password with the call.
So if my authnitication should not be placed under the SIP-UA, how would I send it? They also said that they do not want be to register my SIP DIDs with them either (for example using a ephone-dn).
Do you have an IOS config example?
Nicholas Matthews Tue, 09/01/2009 - 14:47
  • Red, 2250 points or more
Hi Robert,
I looked at the configuration guide for these commands to clarify a bit, and this is what it sounds like:
authenication .....
This will allow the digest authentication that your SIP provider is looking for. (Sure on this one).
credentials ....
This should send a register message. It's not clear from the command reference whether or not this sends a register message without a DN configured or not, but it doesn't sound like the configuration that you need.
Registrar ..
Unnecessary. Only for registration.
sip-server
This is just a shortcut for being able to type 'session target sip-server' on your dial peers. You can just as easily type 'session target ipv4:x.x.x.x'.
Hope this clarifies.
-nick
robert-knapp Tue, 09/01/2009 - 17:42
Thanks. Thats very usefull info.
The problem I'm having is that the provider does not support digest authenication. If they did I think my config would work. When I debug CME I see that it wants to use RFC3261 but the provider does not.
All the provider can tell me is that they don't want me to register using sip-ua and they want the username/password sent with every call. I don't see how that's possible with CME. The provider claims that they have other CME customers using this method without a problem. I'm starting to question them on this...
