SPA 962 : Changing the delay before dialing
Sep 1st, 2009
Is there a way to change the delay before dialing ?
The current one is too short, and the dialing is often launched before the user has typed the whole number.
icastrov Tue, 09/01/2009 - 06:59
Dear Sir,
please take a look at the SPA9xx Administration Guide, particularly at the dial plan section and its interdigit long and short timers:
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa_wip_admin.pdf
I'm not sure what's the value you have currently set on those timer but I'd suggest you to increase them a little bit in order to allow more time to dial the digits.
Thanks!
-nacho
mediware01 Tue, 09/01/2009 - 07:52
Thank you,
Increasing the Interdigit_Short_Timer value from 3 (default) to 10 did the trick.
