Multiple mac addresses in a scheduled Client session report
Sep 1st, 2009
Is there a way under the report criteria to specify multiple mac address. I know you can do one mac address or "All Clients" but I would like to print a report for only 5 on one report.
carenas123 Mon, 09/07/2009 - 08:00
Follow these steps after choosing the Schedule tab within any report type.
Step 1 Check the Enable Schedule check box.
Step 2 Specify if you want the export format to be .csv (a file containing the MAC addresses of access points) or .pdf from the Export Format drop-down menu.
Step 3 Choose either the Save to File or E-mail To option as the destination type.
-If you select the Save to File option, a destination path must first be defined at the Administration > Settings > Report page. Enter the destination path for the files in the Repository Path field.
-If you select the E-mail to option, an SMTP Mail Server must be defined prior to entry of the target e-mail address. Choose Administrator > Settings > Mail Server to enter the appropriate information.
Step 4 Enter a start date (MM:DD:YYYY format) in the provided field or click the calendar icon to select a date. The report begins running on this date.
Step 5 Specify a start time using the hour and minute drop-down menus.
Step 6 Click on one of the recurrence buttons to select how often the report is run.
Step 7 When entry is complete, do one of the following:
•Click Save to save the entry.
•Click Save and Run to save the changes and run the report now. The report is run, and the results are either e-mailed or saved to a designated file as defined in the Schedule tab. The report runs again at the scheduled time.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
