2610XM with HWIC-4T
Answered Question
Sep 1st, 2009
Hi Guyz,
I have a question regarding compatibility of HWIC-4T with 2610XM routers.. Have anyone ever tried using HWIC-4T(smart serial) with 2610XM routers on both slots adding upto 8 serial interfaces ??
I want to setup the 2610XM router as a FR switch for simulation using HWIC-4T cards ??
Please advice
Hitesh Vinzoda
Correct Answer by Paolo Bevilacqua about 7 years 5 months ago
You asked, and I answered about HWIC, not WIC. These are different things.
Please remember to rate useful posts with the scrollbox below.
Overall Rating: 4 (1 ratings)
Hitesh Vinzoda Tue, 09/01/2009 - 09:11
i m using 2610XM routers with WIC-2T i.e. Smart serial, perfectly fine..
Hitesh Vinzoda
Correct Answer
Paolo Bevilacqua Tue, 09/01/2009 - 09:14
Leo Laohoo Tue, 09/01/2009 - 13:57
Paolo's right. HWIC will physically not fit into a 2600 router. If you look at the assembly, the HWIC has three rows of pins while the 2600 (and WICs) has a row of two.
