Cisco Hardware VPN to Multitech 820
Sep 1st, 2009
I have a Cisco 2650XM and a Multitech 820 and I am wondering if any one has any experience getting a VPN up between the two types of routers? Attached is the IPSec setup screen for a multitech.
Any Ideas?
cbvisser1 Thu, 09/03/2009 - 07:32
The version I have does support IPSec because I have a VPN up between two cisco routers with this version: flash:c2600-jk9s-mz.123-17c.bin
What is the pfs?
Thanks so far
Giuseppe Larosa Thu, 09/03/2009 - 20:36
Hello Chad,
pfs = perfect forward secrecy improves encryption
follow Pompey's suggestions starting as simple as possible is the best approach.
Hope to help
pompeychimes Thu, 09/03/2009 - 19:31
Where exactly is it failing? Are you getting passed phase 1?
When i run into trouble with VPN's I like to dial down the enc/hash level. I also like to remove any superfluous stuff. Try establishing a 3DES/MD5 SA using a basic key (cisco12345) default timers and no PFS. Don't use FQDN's either until your sure you can establish the SA using just the IP.
