OID (SNMP) Manage Firewall lan-to-lan
Sep 1st, 2009
Hi all!
I need to know which OIDs (SNMP) I can use to manage VPNs lan-to-lan that firewall establish.
Firewall ASA.
Aprecciate any help!
Thank you
merabtavart Fri, 07/22/2011 - 01:49
Advantage   of VPNTTG over other SNMP based monitoring software’s is  following:   Other (commonly used) software’s are working with static OID  numbers,   i.e. whenever tunnel disconnects and reconnects, it gets  assigned a  new  OID number. This means that the historical data, gathered  on the   connection, is lost each time. However, VPNTTG works with VPN  peer’s  IP  address and it stores for each VPN tunnel historical  monitoring  data  into the SQL server and into the RRD (Round Robin  Database) file.
