User tracking for Point 2 Point AP connections.
Sep 2nd, 2009
I have end hosts connected to AP's connected with P2P connections ... is there a way to have user tracing for these hosts.
CW -> switch -> 1242AG -> 1242AG -> end hosts
CW -> switch -> 1310G -> 1242AG -> end hosts
Joe Clarke Wed, 09/02/2009 - 10:11
This will not work. You need to upgrade to CM 5.1.3, then you will be able to acquire users directly connected to standalone APs provided those APs are configured for multiple VLANs.
Rajiv Dasmohapatra Sat, 09/12/2009 - 00:57
I upgraded the CM.
As suggested, I tried to configure the P2P link. But here we are using 802.11a for the communiation between two APs'using native vlan only and 802.11b for the end host connection.
When i try to configure the VLANs in the first AP, i lose connection with the second AP.
The configuration of both the APs' with the N/W diagram is attached herewith.
Joe Clarke Sat, 09/12/2009 - 08:56
I don't use Visio, so I can't view the topology. To which AP are the users connected? Is this AP managed by Campus Manager, and showing up as green on the Campus Topology Map?
Joe Clarke Sat, 09/12/2009 - 13:07
You also need to make sure the AP properly supports the Q-BRIDGE-MIB. Post an SNMP Walk from the non-root bridge AP (I suppose this is where users are directly connecting) of 1.3.6.1.2.1.17.7.
Rajiv Dasmohapatra Wed, 09/23/2009 - 05:01
Hi joe,
I configured VLANs on both the devices but after configuring it i cant get to make them talk between themselves. not sure if this is the correct way. attaching the configs for both the APs'.
Joe Clarke Wed, 09/23/2009 - 07:21
I am not a wireless expert, and I do not want to make config recommendations. You might try asking about recommended bridge configurations on one of the wireless forums.
