RSA key auth error on ASA
Answered Question
Sep 2nd, 2009
I am trying to authenticate cisco 851 on ASA 5520 using digital certificates from MS CA. Got this error:
CRYPTO_PKI(make trustedCerts list)CRYPTO_PKI:check_key_usage: ExtendedKeyUsage OID = 1.3.6.1.5.5.8.2.2
CRYPTO_PKI:check_key_usage: ExtendedKeyUsage OID = 1.3.6.1.5.5.8.2.2, NOT acceptable
CRYPTO_PKI:check_key_usage: No acceptable ExtendedKeyUsage OIDs found
Correct Answer by Yudong Wu about 7 years 9 months ago
It looks like EKU(ExtendedKeyUsage) does not match. You can try to disable EKU check by adding the following command under trustpoint config:
ignore-ipsec-keyusage
Overall Rating: 5 (1 ratings)
Correct Answer
Yudong Wu Wed, 09/02/2009 - 11:22
  • Gold, 750 points or more
