importing C300 config to C360
Sep 2nd, 2009
did anyone try importing the config of c300 to c360 without any issues?
what are the assumptions.
im planning to replace my c300 with c360.
kira
Andrew Wurster Wed, 09/02/2009 - 17:29
kira -
- make sure the versions are same for sure.
- make sure your exported config has the passwords unmasked
- if the import command fails, it will give you an unexpected element or tag message, so if you see those, just comment them out in your XML source file and retry the operation.
best of luck.
andrew
angfeglandagan Thu, 09/03/2009 - 02:53
thanks for the reply...
i was able to make it work by eliminating the parse message indicating some unsupported lines in my xml config.
i was able to load it with no errors after removing as what the error told me..
more power.
