CDR System Reports
gogasca Sat, 09/05/2009 - 01:21
  • Green, 3000 points or more
Which type of GW you are referring to (MGCP, SIP or H.323) and which report you are running?
You can check "Documentation Updates" of cucm 7 (Cisco Unified
Communications Manager CDR Analysis and Reporting).
Its a H.323 GW
I can see call stats from CDR and search for gateway (selecting the problem gateway)
However when I select device reports and search by gateway (selecting problem gateway) I don't get any stats.
It reports for CDR but not device reports.
All 6 other gateways produce reports from both device manager and CDR?
Strange
Rod
