AA in CCME
Answered Question
Sep 2nd, 2009
hi,
i'm using ccme 7.0 and cisco unity express, i have configured voicemail and it works fine.
now i need to use AA, what i need to do?
i shud use B-ACD, or just the script aa.aef.
please help
Correct Answer by david-lima about 7 years 10 months ago
Hi, to create a new script, you need to download a Cisco Unity Express Script Editor, create a script according to your needs and upload it, you can refer to this quick start guide.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008041d950.shtml
All the best
David
Hi friend, in my opinion, the CUE-AA is a nice option, with this option you can customize your script, the only think that you need to considerer is the the VM and AA share the available CTI ports.
All the best
David
Overall Rating: 5 (2 ratings)
Correct Answer
david-lima Wed, 09/02/2009 - 05:12
  • Bronze, 100 points or more
All the best
David
bsaid1977 Wed, 09/02/2009 - 05:33
hi David,
thank you for you replay.
i will just tray the default AA befor thinkig to customaize it.
i have configured ccn application autoattendant with maxsession 3.
because i have 6 port, 3 for voicemail, and 3 for AA.
i have configured the pilot number, when i call this number i don't hear th greeting.
thanks
bsaid1977 Wed, 09/02/2009 - 06:00
the default AA is now running, now i configured the number that i need to call from an internal phone to customize the gretting but i don't hear anything.
so i miss something to use Avt.
many thanks
david-lima Wed, 09/02/2009 - 06:34
Hi friend, check if the the aa script is associated with a pilot number and enabled from gui: voice mail->autoattendant, also verify in your router configuration that you have the dial-peers for the aa and avt.
dial-peer voice 2040 voip
description CUE-AA
destination-pattern 2040
session target ipv4:a.1.11.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
All the best
David
bsaid1977 Wed, 09/02/2009 - 07:28
ok , thanks David.
now the default AA is working fine.
And I can access to Avt.
now i shoud begin the trip: how to creat a new Script for my AA ?
thank you David, you are graet!!
