09-02-2009 04:57 AM - edited 03-04-2019 05:55 AM
Hi ,
I have eigrp over tunnel.During monitoring the tunnel through solarwind observed too many transmit discards for below tunnel.
sh int tu0
Tunnel0 is up, line protocol is up
Hardware is Tunnel
Internet address is 10.254.11.98/30
MTU 1514 bytes, BW 10000 Kbit, DLY 100 usec,
reliability 255/255, txload 179/255, rxload 248/255
Encapsulation TUNNEL, loopback not set
Keepalive set (10 sec), retries 3
Tunnel protocol/transport GRE/IP
Key disabled, sequencing disabled
Checksumming of packets disabled
Tunnel TTL 255
Fast tunneling enabled
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:49:58
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 674
Queueing strategy: fifo (QOS pre-classification)
Output queue: 0/0 (size/max)
5 minute input rate 9806000 bits/sec, 2019 packets/sec
5 minute output rate 7035000 bits/sec, 2019 packets/sec
10376324 packets input, 1355200320 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
10334112 packets output, 3480887620 bytes, 0 underruns
Link has 10 Mbps capacity , configuration is as below.
interface Tunnel0
bandwidth 10000
ip address x.x.x.x
ip load-sharing per-packet
ip tcp adjust-mss 1380
delay 10
qos pre-classify
keepalive 10 3
Can somebody help to resove this issue.
09-02-2009 07:18 AM
I remember your previous posting.
You are shaping to 9Mbps on the FastEthernet interface that is facing your MPLS provider.
If the tunnel is sending more than 9Mbps, your FE interface will buffer that traffic up to a point. Any excess traffic over 9Mbps can potentially drop and that's what's occurring with the tunnel. Looking at your output rate, it looks like you are hovering around that amount.
You need more bandwidth from the MPLS Service Provider or you need to identify who is creating the bandwidth demand and address the problem at the source.
__
Edison.
09-02-2009 11:29 PM
Thanks for reply.
This link is diffrenent than mentioned.
Thoough link utilization is normal like 3 to 4 Mbps , no packet drop in ping but in sh int tu0 ,output drop increases continuously.
09-03-2009 04:19 PM
3 to 4Mbps?
I see more like 7 to 8Mbps based on the output posted.
What's the source interface from the tunnel? What's the bandwidth end-to-end?
Any QoS?
We need more info..
Tunnel interfaces are virtual interfaces and drops occurred in the tunnel are often due to the underlying physical interface.
09-03-2009 08:17 PM
Tunnel source and destination are physical interface.i have fresh capture at 3 to 4 Mb in which tunnel showing output drop but no in phy int.
sh int tu0
reliability 255/255, txload 43/255, rxload 85/255
Tunnel TTL 255
Last clearing of "show interface" counters 00:13:56
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 82
sh int fa1/1
FastEthernet1/1 is up, line protocol is up
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:12:24
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Also no drop observed in QOS for that phy interface.
sh policy-map interface fastEthernet 1/1
FastEthernet1/1
Service-policy output: VOICE-VC
Class-map: CLASS-EF (match-all)
26140 packets, 5812960 bytes
5 minute offered rate 8000 bps, drop rate 0 bps
Match: access-group name VOICE-EF
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 20 (%)
Bandwidth 20000 (kbps) Burst 500000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: CLASS-SIG (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name VOICE-SIG
Queueing
Output Queue: Conversation 265
Bandwidth 50 (kbps) Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
Class-map: QOS-VC-CLASS (match-all)
0 packets, 0 bytes
Match: access-group name QOS-VC-VOICE
Queueing
Output Queue: Conversation 266
Bandwidth 2048 (kbps) Max Threshold 64 (packets)
Class-map: class-default (match-any)
1058141 packets, 254149904 bytes
5 minute offered rate 2406000 bps, drop rate 0 bps
Match: any
