Midlet error
Sep 2nd, 2009
I'm not sure if this is really a problem... it might be more a stupid question :)
When activating the MIDlet service on a 7975 phone with a CTS1000 system, we got the message "Calling Services are stopped. Calls can not be made at this time". We need to deactivate the application again (press the services button) to be able to get the initial screen again.
Another thing, even if you don't subscribe to the service, we got the MIDlet icons... what's the use of having it subscribed then?
If everything works fine, when you go to the "info" section on the phone (info softkey), we should be able to see the "problem" softkey, which we don't see.We thought that this could be caused because the MIDlet service was not activated on the phone (however, we see the icons New Call,Directory,Favorites) but we are not able to get it activated due to that message i was talking about earlier.
Anyone has an idea?
Kurt
gogasca Sat, 09/05/2009 - 01:15
  • Green, 3000 points or more
Hi Kurt,
Hope you a re fine, you can use our TP section which we just added...
Please check the following:
Every time you migrate from xml to java midlet you need to reset the CTS codec.
Tina just sent you today a really good email for troubleshooting steps, please continue working with her.
Im just gonna add them for reference here.
Thanks Kurt
