upgrade from wls to wism module
ericgarnel Wed, 09/02/2009 - 07:43
  • Gold, 750 points or more
check the routing between WCS & the wisms, as wisms will have a unique subnet as part of the configuration with the 6500
ericgarnel Wed, 09/02/2009 - 07:45
Also, you should upgrade WCS to a later version. The 6.x WCS is a lot better in terms of navigation & performance
Rob Huffman Wed, 09/02/2009 - 10:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi FW,
Just to add a note here to the great tips from Eric (+5 points buddy :)
The WCS must be at an equal or higher version level than the WLC/WISM to be able to manage it.
Cheers!
Rob
Lucien Avramov Mon, 09/14/2009 - 18:07
  • Red, 2250 points or more
To add some precision to Rob post:
Not only you need higher version of WCS, you ALSO need the release date of the WCS software must be AFTER the one for the controller.
The dates are posted next to the release notes:
http://www.cisco.com/en/US/products/ps6305/prod_release_notes_list.html
http://www.cisco.com/en/US/products/ps6366/prod_release_notes_list.html
Trending Topics - Security & Network
