password recovery question?
JORGE RODRIGUEZ Wed, 09/02/2009 - 08:38
  • Green, 3000 points or more
Hi, password recovery deals with reseting PIX or ASA password not configuration reset.. so be confident your PIX saved config will be there after you do the password recovery procedure, the runnign config if it was not saved consider it lost if you attempt to do the recovery as you will need to reboot for that, the only statements that are reseted in this process startup config will be system passwords and any AAA configuration you may have.
JORGE RODRIGUEZ Wed, 09/02/2009 - 09:55
Hi, Im sorry but not clear in what context you mean inside the config file IP route, are you refering to having a route statement in the pix pertainign to old server?
