09-02-2009 08:19 AM
I have just had a requirement passed to me.
We have a CSS running a single VIP as far as this is concerned. A single SSL- proxy list but two services running behind that.
That is two content rules, one a layer 4, the other a layer 5. We want to restribct access to the later 5 rule to certain users.
As we are using the same SSL, and only splitting out between the two apps after we have decrypted the SSL I don't think the use of client ertificates will help, nor will access lists as they are on the same IP address.
Any suggestions?
Solved! Go to Solution.
09-03-2009 01:40 AM
You can use an acl like :
clause 10 deny any 1.1.1.1 destination content gdufour/SSL2
As you can see, you can specify the content rule - and not the destination ip.
I haven't tested, but it may work.
Gilles.
09-03-2009 01:40 AM
Gilles.
09-03-2009 07:06 AM
Thanks for the suggestion - looks like it might just fly!
I'll give it a try in the LAB first though!
P.
09-04-2009 02:25 AM
Many thanks Gilles, that appears to do the trick!
Just in case anyone else finds this in a search, this is what I have in the access list. This is from the lab, so no problem being open!
acl 2
clause 11 permit any any destination content client/about
clause 30 permit any 10.1.199.3 255.255.255.255 destination content client/secure
clause 35 deny any any destination content client/secure
clause 40 permit tcp any destination any eq telnet
clause 200 permit tcp any destination 10.1.99.51 eq 80
apply circuit-(VLAN99)
This allows everyone to access the "about" content rule, a single IP to access "secure" and clause 200 is important - it lest the connection come up so that the request can be compared against content rules. A little caveat is that if there is a content rule (eg a L4 content rule) that would allow access to the restricted content, that may allow access.
