QoS on 3750
Sep 2nd, 2009
Hi all,
I deployed QoS on 3750 and i want to know if the previous marked packets are in the right queue.
On the router we can do that with sh policy-map interface fastetehrnet 0/0 output for exemple
is there any equivalent command??
Thanks for help
Malek
Overall Rating: 4 (1 ratings)
simontibbitts Wed, 09/02/2009 - 09:10
  • Silver, 250 points or more
Hello Malek.
You can use 'show mls qos interface gix/x statistics' to view stats on the actual incoming DSCP packets.
From that you can determine what queue packets will be entering.
I think that is the best command that I think you are looking for.
Kind Regards
Simon
