09-02-2009 09:59 AM - edited 03-15-2019 07:36 PM
I want to set up a voicemail box with an auto attendant script so that when we transfer people to it they get some different prompts and things they can do, we already have an auto attendant set up for one number, can I set one up for this voicemail box? I set it up as a general delivery box in the unity express 3.1 web GUI, I see how to make scripts but I can't figure out the rest.
Solved! Go to Solution.
09-03-2009 04:44 AM
You can either telnet or console to the router to access the CLI. If you do "show run", you will see several dial peers. One should be similar to:
dial-peer voice 10 voip
destination pattern
session protocol sipv2
session target ipv4:1.1.1.1
codec g711ulaw
no vad
You can add an additional dial peer with your new AA number.
Brandon
09-02-2009 11:04 AM
Sounds like you need to setup another auto attendant with a different dial in number as opposed to a mailbox. Under Voicemail > Auto Attendant, you would add a new AA, associate a script and give it a dial in number.
Hope this helps.
Brandon
09-02-2009 11:52 AM
Okay I did that but when I dial the number instead of the AA script, I get a busy signal, I can't figure out what I am missing? And do I point it at the mailbox I already have?
09-02-2009 11:54 AM
I'm assuming your CUE is integrated with CME? You will need to create a new dial peer or modify your existing AA dial peer to include the number that you assigned to the new AA.
Brandon
09-02-2009 12:01 PM
It's all in one device, I'm using the CUE 3.1 web GUI, the other AA that works doesn't have a number that shows up in the extensions or anything so I'm not sure where I put this dial peer in? I think that's the only part i'm missing all your help is much appreciated.
09-03-2009 04:44 AM
destination pattern
codec g711ulaw
no vad
Brandon
09-03-2009 05:25 AM
Okay I'll try that out, thats kinda wack you'd think there would be a way to do it in the GUI for the none command line masters.
09-03-2009 07:42 AM
Okay that worked thanks man, now onto my next thing, the front desk girl wants to give people the option when they call to hit a number like 1 and have it send them to an external company number, I figured that out easily but does anyone know if that will count against our long distance or does the AA script totally transfer the person out of the system?
09-03-2009 07:44 AM
This would count against your LD. It would also take up 2 lines - one for the incoming call, one to send the call back out. The call would be hairpinned through your system for the duration of the call.
Hope this helps.
Brandon
